16" Wheels
From adelaide
hey guys, bought a pair of rims today, with 205/45/16 tyres today, reasonably cheap. i am intending to put them on a stock '71 sedan. i am unsure about offset, as i dont know how to mesure it! but here are some pics anyway if it helps??? i am just looking for any opinions on the best way to get them to fit?? or what have other people done, if any one?? cheers
wheel
wheel 2
the pictures wont load properly so i sent the link instead!
Posted on: 2008/1/17 9:01
Re: 16" Wheels
From Burbank, CA
well the good news is they're so FWD offset that you could get lug adaptors made.
the bad news is those adapters probably aren't road legal where you are.
oh and also you'll probably have problems with the tires rubbing the fenders.
Posted on: 2008/1/17 9:43
|||\ 81 KPB310 /|||
Re: 16" Wheels
From Adelaide, Australia
They will hit the strut, if you space them out they will have to lip the guard heaps. My pintara stockies which are 14x5 and about +25 offset hit the drum strut I needed a 3mm spacer to clear that and only had about 8mm to the guard, and because of my castor I had to cut the front of the guard away. That was with 175x60x14's bridgestones, I dont think your going to get them to fit.
Are they even 114.3 pcd?
In regards to offset, those wheels you have there would be about +60 or more. Which spaces the wheel 60mm inward from the centreline of the wheel. Ie. Zero offset means the hub mounting face is in the centre of the wheel.
Posted on: 2008/1/17 9:54
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: 16" Wheels
From Sydney, Australia
back of a sedan is tricky for 205s. The inner guard is stepped to reinforce the door opening. Mine rubbed on there badly before I got stiffer springs.
Posted on: 2008/1/17 10:47
Re: 16" Wheels
From adelaide
yeah they are 114.3pcd, they fit on the hub. but hit the strut. already contemplated getting spacers and longer studs, but thought id ask first, dont wanna be throwing away money for nothing. but i doubt ill bother if they are going to hit the fenders too. too much stuffing around for now, ill stick with my 14' stockies. i guess the next question is, will i have trouble fitting my 14' wheels, not sure what they are off of either? sorry for the lack of info on everything. havnt had a great deal of experience with dattos.
stockies
Posted on: 2008/1/18 6:27
Re: 16" Wheels
No they look a little better, your running drum struts right?
What are those meshie rims in the background?
Posted on: 2008/1/21 11:29
IPRA Build
Re: 16" Wheels
From melbourne
hey i have 16s with 195/45 and have no dramas rubbing anywhere on my sedan just watch how much you lower it and use spacers to fit it to get +20which is what i have you may need +25
Posted on: 2008/1/21 22:06
Re: 16" Wheels
Ah, the ever popular 15-spoke wheels.
Wheel 1
[url=http://s60.photobucket.com/albums/h16/datsik1200/?action=view
Posted on: 2008/1/22 4:08
Re: 16" Wheels
From Alice Springs
i can see why they're popular!
Posted on: 2008/1/22 5:12
