Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP
when putting in the ca18det and transmition, do i need to modify the fly wall to make it fit? or will it just slide in? where can i get engine in gear box mounts for these?
you have to make the mounts and most people make up i gear box out of 2. the 5 speed and the stumpy one from the ca20's for the shifter part from memory
drive shaft = get a custom one made cut down to suit the size
diff = 1200 ute diff is h165 and ok for the job other wise you will have to cut down one from another car to fit
brakes = there are sooo many options
suspension= youd be crazy not to, stock handles like rubbish
tips = USE THE SEARCH bar and the tech section links to the wiki... its all in there
Posted on: 2008/1/22 8:14
Subject Poster Date
     Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP SlipStreamRacing 2008/1/22 7:45
       Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP Anonymous 2008/1/22 8:14
       Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP sssute 2008/1/22 8:18
       Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP Dodgeman 2008/1/22 8:48
         Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP beattie 2008/1/22 9:10
           Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP Coops 2008/1/22 9:53
           Re: Dato 1200 conversion to ca18det... CAN ANYONE PLEASE HELP Steveo_1987 2008/1/22 10:07
