Re: bluebird struts
From Christchurch NZ
You have to swap the top hat, and use a B310 steering arm, with an adapter ring to spigot them together. You may also need to "massage" the inside of the strut tower due to the larger coil diameter. Whle your at it, you should go for the longer "HB310" ball joints to improve the camber.
Posted on: 2008/1/30 3:48
Forced Induction!
Subject Poster Date
     bluebird struts bluedat 2008/1/30 2:26
       Re: bluebird struts A14force 2008/1/30 3:48
