Re: What is a boxed carby?
From Brisvegas, oz
i didnt like the carby idea myself thats why i went for injection but it worked fine on low boost, i would be interested in how cheap you can actually make the carby hats, thats just how much i paid for it, stainless and tig welding labor aint cheap. but good luck
Posted on: 2008/2/1 10:54
www.camerasplus.com.au
From NZ
The purpose of the box or hat is to equalise the pressure acting on the carb jets.
Carbs rely on the ventury/suction effect of the air going through the carb to suck fuel through the jets to create the air/fuel mixture your engine runs on.
If you just pressurise the air intake on the carb no fuel will get into the engine - it will just blow air backwards through the jets.
Sealing the whole carb as opposed to just the top ensures air doesn't get blown out around the throttle spindles etc.
You also need to devise to keep the fuel pressure at around 3-4psi above boost pressure.
Posted on: 2008/2/1 11:05
From Bendigo, Victoria, Australia.
stainless is a bit much these days. even if i could afford to look good i would still do the welding myself. EFI is a bit excessive for my goals at the moment, so i'll stick with my 32/36 and see how far it gets me
frankthedolphintrainer was it you that had the turbo manifolds made? if i do decide to go ahead with this i mite get one off ya. but i'll let ya know anyway.
thanks for the info lads
Posted on: 2008/2/1 13:50
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From sydney
For what its worth, if I was about to embark on this caper I would get a big SU and go draw through, with water/meth injection decent boost is still possible without an intercooler.
Posted on: 2008/2/1 20:20
From Brisvegas, oz
yeah i had the manifolds made up wont be able to get them for about 6 months now as im going over seas
Posted on: 2008/2/1 23:22
From Everywhere, mostly Melb/Geelong/Ballarat
I'm with you Sidedraught. Just finished a suck through manifold yesterday and am now trying to find a 1 3/4 Su. Not sure where to plumb the water/meth yet because I don't want to pit my turbo.
Posted on: 2008/2/1 23:25
From sydney
I do still have one of Frankthedolphintrainers turbo manifolds, brand new, $300.
Posted on: 2008/2/1 23:36
From Springwood NSW, Formerly Tas.
how do you get the throttle cable through the box? poke it through a hole and silicone it up?
Posted on: 2008/2/4 0:49
1978 120y Coupe.
From Burbank, CA
hehe blow through propane systems are cool :)
no carbs to box or anything, just add a boost reference line on the vaporizer and away I go...
it's gonna be cool!
Posted on: 2008/2/4 1:51
|||\ 81 KPB310 /|||
From Brisvegas, oz
thats a good question, which is why i never went down the boxed carb way. i thought of using a carby throttle piece that connects to another throttle piece which then connects up to the internal carby. i know it sounds crazy but that was the best design i thought of and the method of using a bolt to turn the throtle aswell but they both have there flaws.
Posted on: 2008/2/4 9:29
« 1 (2)
