how dificult to get approx 100-120hp out of an a12?
I got my stock free engine begging for a rebuild on the garage floor, with my cars problems, was looking at how much work and more importantly how many $$$ to get around 100 hp out of it. Any Build plans done yet?
When its built, may look at blow through finally for my current engine or 12a conversion... just lloking for some mild na power at prestent.
Anything better than 69 max hp
Posted on: 2003/5/12 8:04
Re: how dificult to get approx 100-120hp out of an a12?
From Auckland N.Z
ive got an a12 motor which was dinoed at 100hp at 6500rpm and it was still pulling but the guy didnt know what was in it so he didnt take it higher. all its had done to it is a port and polish and twin 40s and extractors. so as long as the bottom ends good all you need to pay for are the carbs and the headers coz you can port it yourself. cheep horsepower!!
Posted on: 2003/5/12 13:34
From Melbourne, Australia
i bought my motor with about 100hp
it had (as far as i know):
gx head
twin 42mm webers
bored 40 thou
and BIG cam
gx exhaust
electric fuel pump (dunno if this helps horsies but makes carbs run better)
Posted on: 2003/5/13 10:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Auckland N.Z
maby my motors had more done to it than i thought. the guy i got it off said he had done a bit of work which i presumed head work only coz he didnt say anything about the internals.
sweet.
Posted on: 2003/5/13 14:08
mate dynoed at 100hp, did he mean at the wheels???
mine was dynoed and got 56kW at the wheels which i figure is about 100 flywheel hP
Posted on: 2003/5/13 14:14
1200 Coupe Rallycar
From Brisbane
56kw at the wheel = 74.6hp at teh wheels
Posted on: 2003/5/13 14:21
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
yeah something like that and then add around 20 or 25hP for drivetrain losses
i discussed it on this site previously and me and others came to the conclusion it would be 100 or just under at the flywheel
i'm not that fussed
"torques cheap, let's race"
Posted on: 2003/5/13 14:28
1200 Coupe Rallycar
My a15 was dynoed at 112 at the wheels with the 38mm mikunis bike carbs tuned length 4 into 1 ext. self ported head (my first one! from following a ford cleveland guide) and unknown cam and block from speedway car. I glazed the bores and warped the head with a leaking heater hose on a 40 degree day. I then put an a12 with another match ported head to the miks and sold it a guy from sydney. it was my first 1000 coupe on a small budget and after missing it I got hooked again on the small buggers as I couldnt find someone who could build reliable rotaries as they usually like volksies re use internals which last not far beyond the warranty period but give them the unfairly tags them as unreliable. The r100 bug was squashed by the rarely stolen or hard to find parts datsun brand.
Still miss the power but not the cops, muffler joint and arrsewipe maztech.
Posted on: 2003/5/14 1:24
so theory has it, an a12 with twin carbs, 4 into one extractors, big cam and possibly higher comp would get aprox 100 hp... at the wheels, with a tail wind?
cheaply?
Posted on: 2003/5/14 13:19
From Auckland N.Z
yea my datto was dynoed at 78hp at the rear wheels which is close enough to 100 horse at the flywheel but theres also the fact that each dyno is slightly different so as 1200rallycar said talk is cheep lets race.
Posted on: 2003/5/14 13:36
(1) 2 3 4 »
