CA Inlet Question...
From Radelaide, South Australia
Me Again...
getting a custom inlet manifold made for the ca but i think i may have a problem...
1.... In the red there is a water jernol.. can i block that up?? as it goes strait into the head, on the head side of the manifold.. but i may circulate somewhere yea??
2.... In the yellow you can see inlet holes or somthing... can somoe explain what i can do about these??
Thanks Again.... Dane...
Posted on: 2008/2/5 23:51
Boost.. boost.. BOOST!!! Gotta love Lag...
* 76 coupe, twin 40mm a12, project...
* 79 ute ca18det, track/street...
* 84 FJ45 landcruiser project...
* 88 D21 navara 4x4, sr20de vvt daily...
Re: CA Inlet Question...
From Newcastle
thats a fwd ca isnt it casue dont think mine has any of that. . .and mines rwd correct me if im wrong though
Posted on: 2008/2/6 0:25
yea mate...fwd
Posted on: 2008/2/6 2:08
From perth airport
Posted on: 2008/2/6 5:37
perth airport parking
Datsun 1200 ute A14
From Schofields
Posted on: 2008/2/6 9:17
From Brisbane
is this non turbo or turbo, i would change the fuel rail to rwd at the same time, (then a Rwd plenum will fit)& alot easier to upgrade the injectors
Posted on: 2008/2/6 12:03
thanks will have a look at the link...
as for the fuel rail, i have no reason to change it or move it as its using turbo injectors allready and the plennum chamber is diff from the rwd and the fwd.. otherwise i would have just changed it allready...
Cheers... Dane...
Posted on: 2008/2/7 4:27
