Re: how dificult to get approx 100-120hp out of an a12?
From Sydney, Australia
A few months back, at the Datsun Nationals in Sydney.. I saw an A15 powered 1000 Coupe get 76kW (could have been 78) at the wheels. That's the same amount as my old CA18DET Which got 78rwkW ...We all agree now that there was something wrong with my old CA. But that fellas 1000 was an inspiration. It really made some noise on the dyno..very cool.
Chris
Posted on: 2003/5/14 14:05
From Christchurch New Zealand
if my calculations are correct due to cam duration and compression i should have 132HP at the fly
Posted on: 2003/5/15 8:58
"If your not living on the edge your taking up too much space" Rod Millen
From Melbourne, Australia
ya gonna tell us about the motor rally-a-coupe or ya just gonna leave us wondering
Posted on: 2003/5/15 10:43
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
10.1:1 compression ratio .ported head ,doubble valve springs ,wild cam should make power between 4500rpm to 9000rpm,lightend flywheel ,balenced bottom end ,A14 pistons,twin 40 ml dellorto's ,extractors
Posted on: 2003/5/15 10:53
sounds kinda like my motor, except the 1400 bit, so all i gotta do is build an a-12 block with a-14 gear to get an extra 32Hp, sounds good to me
use of a-12 block is to comply with rally rules
Posted on: 2003/5/15 10:56
1200 Coupe Rallycar
A14 pistons give you close to 1300cc
Posted on: 2003/5/15 11:03
yeah but can i use the a-14 crank to achieve 1400???
Posted on: 2003/5/15 11:04
1200 Coupe Rallycar
From Fort Worth, Texas, USA
To use the A-14 crank, you'll have to find shorter connecting rods. If you don't, the pistons will pop out of the top of the bores. Or crash into the head, if you got that far before turning the crank during the build!
They, Nissan, raised the deck height when they "stroked" the engine.
Posted on: 2003/5/15 15:48
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From Okinawa, Japan
Are custom pistons with higher wrist pin locations available?
Posted on: 2003/5/15 16:45
The A10 rods are shorter than the A14 rods ...
Posted on: 2003/5/15 21:57
« 1 (2) 3 4 »
