Re: 1200 steering box rebuild/replace - what options?
Dodgy conversion? You didn't even see it. It was nice work, he even lined up the new linkage in the same plane as the original linkage. DAT383 did a rack conversion, as did someone using Escort struts on a B110 circuit car. I haven't heard much about how those turned out.
If my choice is 35-year old worn out gearbox or an "some-say-it-can't-be-done" conversion, I'll give it the benefit of the doubt. Just because some race car builders have found a great solution doesn't mean it is the only way, or that it's not good for a street car.
They might also tell you that Nissan's original B110 steering gearbox solution isn't great for a circuit car. But it works well enough for most of us.
Posted on: 2008/2/19 7:15
From Brisbane, Australia
well escorts have racks, so if he used or replicated an Escort front end in the Datto, that would probably be a decent solution. plus you can get quick racks for eskies too.
DAT383 is a drag car. so steering geometry probably isn't his biggest concern. it may be done very well though, there's a fair bit of engineering in that car from what I've seen.
I'm not saying it isn't possible, just not really feasible for a road car.
Some bloke who's just done it himself because he doesn't like to listen to people who know better telling him it isn't the best idea - chances are its geometry is all over the place.
When people who do this stuff for a living on race cars and know about steering geometry and setup tell you it will be very difficult to get even acceptable geometry in the confined space on a road going 1200 with CA in it, with numerous attempts at modifying steering arms to rectify the issues... all that labour is going to add up. As I said it really isn't feasible. And that's assuming you can even find a rack the right width in the first place - near enough really isn't good enough.
but feel free to disregard knowledgeable opinion and just bung it together yourself and hope for the best.
for a race car, or performance road use, a slightly vague steering box with decent geometry will be a much better solution than a nice tight steering rack with poor geometry.
Posted on: 2008/2/19 22:06
« 1 (2)
