help with shaving tray lip
From sunshine coast QLD
im after any pics tips or info on shaving the hooks n lip on my 85 ute.. im not gonna grind the tray n back of the cab all of in 1 go as i think it makes it harder welding n getting evrythink str8 in the end( i will b doin a few inches at a time ie grind tack grind tack) ..just need some help on how 2 finish it off after i grind n tack it all together (will b fully welded though) the main problem i have is the back of the cab
any info will b gr8
Robert...
Posted on: 2008/2/20 2:39
Re: help with shaving tray lip
anyone
Posted on: 2008/2/20 5:09
From South Brisbane, QLD
patience... you will get an answer soon...
I haven't done what you want to, but I know that those hooks are easy to get off you just drill out the two spot welds that hold them on, dont need to drill much just enough to get threw the weld.
I know thats not what your after but may help you a little.
Posted on: 2008/2/20 5:14
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
From Rocky Queensland
check the pics in my profile cmy_1200. i have the lip and hooks shaved. cant help with how it was done tho cause it was like that when i got it.
Posted on: 2008/2/20 5:45
From Brisvegas, oz
dont be scared to give it a go.
i just cut the whole thing of in one go i do regret not fitting extra bracing under the top part before i high filled the lip tho. i expect it to crack but there maybe some ways around it.
theres a few picks in my photos aswell
Posted on: 2008/2/20 9:38
www.camerasplus.com.au
yeah thats what mine is lacking. its cracked a little bit. make sure you have a good spraypainter. cause my paint has lifted just under where the lip has been cut off
Posted on: 2008/2/20 9:56
From Brisvegas, oz
good you say......well im the best man for it. lol (im spraying mine, sick of when people say to you did you do all the work yourself and you go yes....um well i payed for it all.)
Posted on: 2008/2/20 10:01
yeah i know what you mean.. im honestly thinking about doing the whole thing again and going sr20turbs. just talking to my engineer at the moment to try work stuff out. moneywise its probably a long way off tho
Posted on: 2008/2/20 10:13
yeah i got a m8 painting it hes been painting cars 4 nealy 20yrs so he should know whats hes doin.. its gonna be metallic teal green with mayb some white pinstriping on the tailgate. just like the shaved look but im bit iffy when it comes 2 behind the cab. when all the lip is cut off is there much of a gap left or is it just a mill or 2 that has 2 b welded?
Robert..
Posted on: 2008/2/20 10:28
From Brisvegas, oz
there is no gap it mates up perfectly, beware the side panels are quite thin.
Posted on: 2008/2/20 10:44
