« 1 (2)
Re: ca18det dies when turbo spools up
I would put my money on an Airflow meter/ air leak problem.
Start with cleaning the element with alcohol because they can get gunked up. You may be hitting the boost cut with a confused computer.
Check again that there are no air leaks from the back of the airflow meter to the inlet manifold. Also check you have all the fitting plugged up on the inlet manifold because there are a hole heap of them that you don't use.
Posted on: 2008/2/21 8:22
From brisbane
this is very common on hotwire a/f meters, i would have cleaned this first as well
Posted on: 2008/2/21 9:53
Ryan
From melbourne
sounds more like blocked exhaust mate, had that with a fair few turbo motors
Posted on: 2008/2/23 7:47
Why would it be a blocked exhaust? He doesn't have a cat and the thing dies, it's not just down on power.
Posted on: 2008/2/23 8:17
From perth airport
the guys at the shop are very buzy but the out come atm they think not confermed if afm or fule pump, should know on monday
Posted on: 2008/2/23 11:38
perth airport parking
Datsun 1200 ute A14
« 1 (2)
