wats the average cost to get everything done correctly, starting from scratch, by that i mean buying motor and gearbox and installing?
My interpretation of doing it correctly would be to do everything at once. No skipping brakes or tellling yourself that you won't go hard on the standard diff. Imagine getting the engine in and running and going on your first drive only to find you can only putt round in it...boring!
Just save up until you have enough money to do the WHOLE conversion proplerly. That way you won't have to worry if you're going to leave the diff behind while leaving every set of lights or if you're going to be able to stop before the next set.
That's what I've done anyway.
If you want another combo of what people are using, I'm getting a commodore diff with commodore front brakes as well. That way I get 5 stud pattern all round as well.
