Browsing this Thread:
1 Anonymous Users
Blower Setup on ebay |
From Perth Western Australia
Hey anyone seen this one? Bloody Huge BlowerIt's almost bigger than the A-Series block!!
Posted on: 2008/2/25 9:08
---------------------------- Datsun 1000 it's All-round Action! ---------------------------- Thou Coupe worked A14 twin bbq's
Re: Blower Setup on ebay |
From Canberra
hmm thats a lot of weight hanging off the inlet manifold. Would be way out teh bonnet too.
edit: All that effort and its for round port head...
Posted on: 2008/2/25 9:11
From The garage, NZ
stupidest thing i've ever seen haha. Huge respect to anyone who got it running well though
Posted on: 2008/2/25 9:13
From Adelaide, SA
The dudes got -1 feedback. I'd be staying well clear of this deal...
Posted on: 2008/2/25 10:47
The round port head won't matter so much as the intake mix is going in under pressure, so it will probably be OK even with the small valves. It's the exgaust that might need a little attention simply because there will be so much more of it. Big ports are good in NA engines because the pressure that's pushing the mix in there is never more than 1 bar absolute, so we need all the cross section of port size we can get, but with boost, you can feed an engine through a drinking straw. [almost] There must surely be some additional support for the weight of the blower. If not, I can't see that manifold lasting long. It says GM blower, but I wonder which model.
Posted on: 2008/2/25 13:35
Love your Datsun. Treat it well.
From Canberra
Quote: Dodgeman wrote: The round port head won't matter so much as the intake mix is going in under pressure, so it will probably be OK even with the small valves. It's the exgaust that might need a little attention simply because there will be so much more of it.
But then if you look at the FJ20 for example, some say the inlet ports are too big as a N/A engine, but in turbo models porting them further provides some good power gains.
Posted on: 2008/2/25 21:08
From Gold Coast
Someone should buy it,they look cool here is my old setup.
Posted on: 2008/2/25 22:36
From Los Angeles,CA. USA
i would LOVE to buy it! But seller does not want the hassles of shipping it
Posted on: 2008/2/27 5:22
Turboute, did you get it all to fit under the bonnet? Looks a little tight.
How about supporting it?
Posted on: 2008/2/27 6:30
From Canberra
Quote: clyons8 wrote: Turboute, did you get it all to fit under the bonnet? Looks a little tight.
Posted on: 2008/2/27 6:51
