turbo gains
From Whitsunday's NTH QLD OZ
What sort of gains would ya get out of a standard 1200 with turbo , eg hp 1/4 mile times etc , just rough ballpark figures , i know there are a lot of veribles
cheers
Posted on: 2008/2/26 20:33
Re: turbo gains
From perth airport
you should have a look in the 1/4 mile thread theres a few a12 turbos in there
Posted on: 2008/2/26 21:01
perth airport parking
Datsun 1200 ute A14
Re: turbo gains
From Brisvegas, oz
i mostly here of around 50 - 90 kwatw but there is that freak engine with 260 or whatever
Posted on: 2008/2/26 22:42
www.camerasplus.com.au
Re: turbo gains
You could easily double the HP (if using intercooler and high boost).
This would result in 1/4 time going from 20 seconds (stock) to 16 seconds (turbo'd).
Datsun1200.com club wiki
Posted on: 2008/2/27 0:13
Re: turbo gains
From Brisvegas, oz
stock atw hp is somthing like 22kwatw if this is correct 15 psi of boost has more than quadrupled the hp from my a12
Posted on: 2008/2/27 2:54
Re: turbo gains
From Burbank, CA
it all depends how you do it.
there's a bunch of math that you can do and figure out if the amount of HP you want to attain is even possible.
15psi is a good target, but without lowering compression you won't be doing it on cheap pump gas.
Posted on: 2008/2/27 3:41
|||\ 81 KPB310 /|||
Re: turbo gains
whats the best carbie and turbo to use
Posted on: 2008/2/27 11:11
Re: turbo gains
i can get my hands on a 1.50 cd stromberg or a 350 holley would any of these be any good for turbo
Posted on: 2008/2/28 9:41
