#1 turbo gains
dartson Posted on: 2008/2/26 20:33
What sort of gains would ya get out of a standard 1200 with turbo , eg hp 1/4 mile times etc , just rough ballpark figures , i know there are a lot of veribles
cheers
#2 Re: turbo gains
perthute Posted on: 2008/2/26 21:01
you should have a look in the 1/4 mile thread theres a few a12 turbos in there
#3 Re: turbo gains
frankthedolphintrainer Posted on: 2008/2/26 22:42
i mostly here of around 50 - 90 kwatw but there is that freak engine with 260 or whatever
#4 Re: turbo gains
ddgonzal Posted on: 2008/2/27 0:13
You could easily double the HP (if using intercooler and high boost).
This would result in 1/4 time going from 20 seconds (stock) to 16 seconds (turbo'd).
Datsun1200.com club wiki
#5 Re: turbo gains
frankthedolphintrainer Posted on: 2008/2/27 2:54
stock atw hp is somthing like 22kwatw if this is correct 15 psi of boost has more than quadrupled the hp from my a12
#6 Re: turbo gains
B210sleeper Posted on: 2008/2/27 3:41
it all depends how you do it.
there's a bunch of math that you can do and figure out if the amount of HP you want to attain is even possible.
15psi is a good target, but without lowering compression you won't be doing it on cheap pump gas.
#7 Re: turbo gains
dartson Posted on: 2008/2/27 11:11
whats the best carbie and turbo to use
#8 Re: turbo gains
dartson Posted on: 2008/2/28 9:41
i can get my hands on a 1.50 cd stromberg or a 350 holley would any of these be any good for turbo
