« 1 (2)
Re: driveshaft/ diffhead clearance
Thanks DD
Its definetlry an H145 tailshaft- the plot thickens!
Posted on: 2008/3/1 22:06
From NSW South Coast
Have I missed something, Have you changed the diff from a h145 to a h165
If you have then you may need to change the yolk on the front of the diff to a sunny one. I have the same problem with the tight tailshaft in our track car. I think mine has to do with our homemade spring seats ( the locating hole is in the wrong place ) It has never caused any problems with it, it only goes on fairly smooth tracks though.
olboy
Posted on: 2008/3/2 9:50
Without knowing just exactly what you have I will make a few guesses from the info provided
1. You have a 1200 car.
2. It has a newer engine, but you used the later crossmember, so it should all be good
3. You have used a 5 speed trans but don't mention which one. None the less, as DD has said, ALL 56, 56A, 60 & 60A series transmissions are the same overall length
4. You still have the H145 differential [?]
If this is the case, then the longer, standard passenger model deiveshaft should fit & work. As far as I know, the driveshaft from 120Y's & B310 Sunny's are also the same length, but they differ in that they have larger universal joints & a larger drive flange at the diff end.
As you now know, the fitting of the H165 rear end from the 1200 ute into a passenger model also requires the use of the shorter Ute driveshaft.
For a moment I had thought that you might have possibly fitted the springs the wrong way around, swapping them end for end, but that's a physical impossibility, unless, .......
Unless the spring works made new top leaves & drilled the center bolt hole after measuring from the wrong end. It is NOT located in the center between the spring eyes.
Is this even a remote possibility?
Posted on: 2008/3/2 10:37
Love your Datsun.
Treat it well.
From Castro Valley,CA USA
yet I would be struggling to have 3-5mm which means to get the drive shaft on and off I have to use a large lever and push the drive shaft hard forward which cannot be good!
Same thing happend to me when I lowered my car. I don't really need a prybar but it's really close.
Posted on: 2008/3/2 14:07
Hi Dodgeman,
Yes, you are correct in your assumptions- A14 endine in a b110 and it still has the H145 rear.
The springs are original and the eyes are untampered with- they have just been flattened and an extra top leaf added.
Interesteing Ange says he had the same problem???
This one really has me stumped- everything on the car has been done properly with absolutely no 'agricultural' type engineering.
I suspect the problem has been exaserbated by fitting the genuine Nissan rear g/box seal as opposed to an aftermarket seal which sat further into the rear of the g/box and no doubt gave the driveshaft just that bit extra of play whereas the Nissan seal has the metal housing and sits prouder in the tailhousing.
Cheers
Dave
Posted on: 2008/3/2 19:07
« 1 (2)
