what to do with ca18 water hoses??
im having drama's tryin to figure out the water hose setup underneath the intake plenum on the ca18det.Just want to know how the other guy's out there setup up there's and if they could post a photo or diagram or somethen plz
to explain it better it's the hoses that come off the T piece on the bottom radiator hose that travel under the intake plenum i found a diagram but it doesn't tell me where a couple end and i wanna know which ones i can block or put into my heater or what??? just somebody tell me lol it's driving me bonkers
thank for any help cheers leith
ps done a search and found some results just nothing specific
Posted on: 2008/3/3 10:33
Re: what to do with ca18 water hoses??
From campbelltown (sydney) australia
you dont really need any of them except for the two that go in/out of the throttle body and the ones in/out of the oil cooler just keep the line going from your i/c pipe to the valve on top of the inlet manifold and your sweet. makes the whole setup much simpler and better to look at. let us know if you need more help theres more you can delete if u live in an area that doesnt get freezing cold in winter.that will keep you going for a day or so....
Posted on: 2008/3/3 12:10
* caution, sunglasses must be worn to view my ca18det *
oh righteo, wat i was gonna do is rip out the metal pipe thats off the t section on the bottom hose and put the big hose that came down from the plenum into t section where the metal pipe used to be and all i was gonna do was run the 2 throttle body hoses to a t join then run it into the bottom radiator pipe, will that work???
Posted on: 2008/3/6 9:58
