Re: Brake problem
From Southern Highlands, NSW, Australia
Make sure you have some clearance between the brake pushrod and the master cylinder piston when the brakes are off. If not the compensating port could be blocked due to the piston not fully retracting and as the fluid heats up and expands, it locks the brakes on. I've had this happen before on a P.D inspection due to bad master cylinder to booster clearance and it resulted in very smoky brakes.
Posted on: 2008/3/6 9:52
'72 1200 sedan hillclimb/supersprint car
Subject Poster Date
     Brake problem rx1200wagon 2008/3/6 5:46
       Re: Brake problem 1200rallycar 2008/3/6 6:16
         Re: Brake problem L18_B110 2008/3/6 6:39
           Re: Brake problem Cable_Tie 2008/3/6 7:18
       Re: Brake problem cheater_5 2008/3/6 8:13
       Re: Brake problem dattodude 2008/3/6 8:23
         Re: Brake problem FAZPIOES 2008/3/6 8:28
           Re: Brake problem dat141 2008/3/6 9:52
             Re: Brake problem rx1200wagon 2008/3/7 7:31
               Re: Brake problem wardat 2008/3/7 11:10
                 Re: Brake problem Freak 2008/3/7 11:21
                   Re: Brake problem Dodgeman 2008/3/9 1:50
               Re: Brake problem L18_B110 2008/3/10 5:59
                 Re: Brake problem PIGDOG 2008/3/10 10:28
                   Re: Brake problem Ronald 2008/3/10 10:37
                     Re: Brake problem Dodgeman 2008/3/10 23:10
                       Re: Brake problem short-coupe 2008/3/11 2:17
                         Re: Brake problem PIGDOG 2008/3/11 5:32
                   Re: Brake problem L18_B110 2008/3/10 11:06
