Sunny front spring question
From gold coast QLD.
Help!I need a Sunny circuit car guru to help me with choosing front coils for standard struts.
Before anyone suggests King Springs,i have already...sought thier advice,spent up big,only to find that what they supplied is way too soft and not low enough by about 50mm....all in all about as usefull as an ash tray on a Harley!
I look forward to your opinions
Cheers Bert Edit. Almost forgot,theres a CA up front
Posted on: 2008/3/13 0:30
Re: Sunny front spring question
From Burbank, CA
was it s13 springs that fit on the sunny struts? I think there was something that worked.
Posted on: 2008/3/13 0:39
|||\ 81 KPB310 /|||
From Brisbane, Australia
I'm not Sunny circuit car guru by any stretch of the imagination, but I'd suggest Gemini coils for the front. In my old 1200 I used them with the variable rate part cut off. I had to wire them in though. Its a cheap option to try at least, to see if it works for you.
I've also used them in a mate's 240Z with very good results.
Posted on: 2008/3/13 0:40
From Geelong, Vic
200b rears will also fit
and corrona springs from a car with double a arm front suspention also work
Posted on: 2008/3/13 2:39
From Tamworth , NSW
hey bert, i have a pair of 200b(im pretty sure) rear springs, they are kings, your welcome to them to use if you like
Posted on: 2008/3/13 2:45
Thanks guys i'm taking all this in.Pigdog have you actually seen 200b coils in operation?If so what sort of ride height over standard do you reckon and what sort of firmness do you think?
Stephen,i may take you up on your offer,we are not far apart
Posted on: 2008/3/13 2:54
From Tamworth , NSW
no worries, ill pm you my details
Posted on: 2008/3/13 2:56
Not going to the dirt sprints at Willowbank Park on Sunday are you?
Posted on: 2008/3/13 3:02
From Tamworth , NSW
nah, hadnt planned on it
Posted on: 2008/3/13 3:11
From Geelong, Vic
you would need to cut the 200b springs down a bit as they are progressive, and longer than 1200 ones
with the softer bit of the spring cut off they are pretty firm, not as firm as the gemini/corrona ones but a fair whack stiffer than stock sunny ones
Posted on: 2008/3/13 3:18
