« 1 2 3 (4)
Re: how dificult to get approx 100-120hp out of an a12?
From Charlotte NC USA
so why not get a bigger candle?
Posted on: 2003/5/21 11:35
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
From Gold Coast Aust
Get the biggest candle and light the thing at both ends ( supercharge the thing and be done with it )
Posted on: 2003/5/21 12:03
Datsun 1200
Keepin' the past in the future
why get a big candle when a little one can light up your life. sounds like you are getting a big candle for more freudian reasoning? tell me about your mother?
Posted on: 2003/5/21 15:06
Mik try content management there is an article under turbo and supercharged http://datsun1200.com/modules/nsections/index.php?op=viewarticle&artid=38
Posted on: 2003/5/22 13:10
Datsun 1200
From Little Rock, AR
My A15 is getting about 115 hp at the flywheel and 86 hp at the wheels. .229 duration cam .414 lift, twin 40 Dellortos, home ported/polished head, oversize Si valves, lightweight chrome-moly pushrods, NISMO comp. headers, electronic distributor w/MSD 6AL, 7lb aluminum flywheel and NISMO clutch, stock bottom end and compression. Could be a little more if I could tune the carbs, WILL be more when I swap in the EFI, intercooler, and turbo.
-Andy
Posted on: 2003/5/24 20:44
From Christchurch New Zealand
A series motors love compression thats where they get most power from
Posted on: 2003/5/28 9:34
"If your not living on the edge your taking up too much space" Rod Millen
From Perth WA
whats the easiest way to get this 'compression' you speak of
in an A14 ??
excuse the ignorance.....
Posted on: 2003/5/28 17:41
My dad just rebuilt an A14 w/stock cam, pistons, etc. for my sister's car. However, he shaved/milled the head something like .120" (hundred and twenty thousandths)!! With a stock A12 Hitachi carb, stock exh. manifold and 2" exhaust this thing sounds really lumpy! I've never driven it, but he claims it makes as much power as his other A14 with bigger cam, stock compression, dual SU's and header. I'll have to give it a spin when I go up there in a few weeks. If compression is really worth that much in the A series I'll be mad that I've been running less than stock for so long (8.5:1), but even so low 16 sec quarter mile is impressive for stock bottom end/compression!
-Andy
Posted on: 2003/5/28 18:28
« 1 2 3 (4)
