ca18 in a 1000 need crossmember pic s
From perth airport
hey i have searched and cant find nothing :( but i know atleast 2 people have done this convershion and if they have a pic of how they did the crossmembers that would help heaps :)
Posted on: 2008/3/12 10:21
perth airport parking
Datsun 1200 ute A14
Re: ca18 in a 1000 need crossmember pic s
From perth airport
bump anyone :)
Posted on: 2008/3/13 9:59
Datsun 1200 ute A14
From Coondle, WA Australia
Try contacting Dattoman1000. I think that this is his long tern project to get a ca18de into a 1k. When i spoke to him about it, the list of mods to get it registered was fairly extensive, so you really wanna do our homework on this if you want a legal road registered car.
Posted on: 2008/3/13 10:14
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From perth airport
thanks mate . its not a road car .... its deadakated burnout car :)
Posted on: 2008/3/13 10:48
Datsun 1200 ute A14
From Perth WA
Well a 1000 and a 1200 share the same original engine yeh? Therefore the X member and mods should be relitivly simmiler shouldnt they? If not just lower the CA into the 1000 bay and see what needs to be done
Posted on: 2008/3/13 11:25
Chris...
From Melbourne Vic
it'll sit too high but if its a burnout car then a hump in the bonnet or a big hornet scoop will help.
Posted on: 2008/3/13 11:47
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Adelaide. SA
I modded the sump & pick up to make the motor sit lower and further back. The bonnet should clear but its still a work in progress.
Adam.
Posted on: 2008/3/13 12:16
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From perth airport
a pic of some one else hard work should give me idears but yea at the end of the day i have to make the mounts :) i pick up the motor tomorro arvo hmmmm its turbo time ooooo yea
Posted on: 2008/3/13 12:59
Datsun 1200 ute A14
From Brisbane, Australia
My 2.2c
Cut the uprights off the crossmember
Put a piece of wood etc 10mm thick on the crossmember
Sit engine on top
Weld on new mounts.
remove wood
It's a burnout car, solid mount it.
Posted on: 2008/3/14 0:18
From perth airport
solid mount it i like your thinking
Posted on: 2008/3/14 2:00
Datsun 1200 ute A14
