Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
question for the turbos
1000Coupe
Posted on: 2008/3/14 4:48
May seem a stupid question, I havent had a turbo before.
Not about my datsun, it hasnt been started in months How do you increase the boost on a turbo, just a couple of psi over stock
#2
Re: question for the turbos
datsonovic
Posted on: 2008/3/14 4:59
You could shorten your wastegate actuator rod on an integral gate,
Or you could use bleed valve or increase the sternal gates spring pressure
#3
1000Coupe
Posted on: 2008/3/14 5:21
so theres no simple adjustment then?
#4
Laney
Posted on: 2008/3/14 5:50
crimp the hose that runs to the wastegate or take it off and il run max boost done this on me exa used to run 8 pound everyday then when i took the hose off the gt28 would spit out round 17pound
#5
1000Coupe
Posted on: 2008/3/14 5:56
I was after a small increase to start off!
#6
A14force
Posted on: 2008/3/14 6:48
Get an airtight vessel, and run a hose from the wastegate actuator line to it. The turbo will have to fill the vessel with pressure before the wastegate can open. This will cause a nice boost increase mid range, but the boost will flatten off in the higher revs.
#7
Tyrie
Posted on: 2008/3/14 6:58
or you could spend $40 and get a turbotech boost controller off ebay....
#8
A14force
Posted on: 2008/3/14 7:37
The method I described only increases boost lower in the rev range, when there is plenty of spare injector cycle available. Reduces the risk of lean out from injectors maxing out.
#9
1000Coupe
Posted on: 2008/3/14 7:55
think i will go with tyries suggestion, more control I dont want to blow it up. thanks for other ideas.
#10
Tyrie
Posted on: 2008/3/14 8:11
I have one of these, was only used for a tune (1hour) then put back in the box. Is missing the silicone hose. Yours for $20 posted if you want it.
http://cgi.ebay.com.au/GFB-atomic-boost-controller_W0QQitemZ270219376005QQihZ017QQcategoryZ130654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem You can view topic.
