Dellorto tune up
Got some old dellortos from a 2ltr alfa as a replacement for my webers which were stolen while transplanting manifolds.
Anyone know a good reference for them on the net? theyre going on a fairly stock a14 with electric dizzy, extractors and lightened flywheel.
Not going mikunis cause the guy who tuned some for me a while ago has gone overseas and no one else does motorbike carbs on a car dyno.
I know Im wasting my time considering Ill be swapping the engine to something twice as powerful thanks to Harry and others like gary hamilton, but ill be a few bue moons before that happens so I will do what I can to the a14 until then.
Posted on: 2003/5/23 3:57
Re: Dellorto tune up
From Little Rock, AR
Well if you've had Webers and Mikuni's the Dellorto's sure aren't much different, but are supposed to be easier to swap parts out for tuning. I haven't found any places in the US that sell tuning parts, but there's a big one in the UK, I can't remember what it's called though, just do a websearch on Dellorto tuning or jets or something. I just drilled out my idle jets because of lack of parts availability and a sickness of an overly lean mixture off idle (backfires through carbs and bucks around at part throttle). So I took the smallest drill I could find and brought it from a 57 to a 79...a bit much, but actually not too rich...I think a 70-75 would be better. The reason mine are so large is because I have a funky style Dellorto that doesn't have adjustable air bleeds for the idle jets....otherwise I'd be using about a 45 on the idle jet. Runs better though good luck w/your carbs
-Andy
Posted on: 2003/5/23 5:27
