Browsing this Thread:
1 Anonymous Users
Tubbing a 1200 ute |
looking for some info on tubbing a 1200 ute.
can someone please explain the process briefly
thanks
Posted on: 2008/3/27 1:07
Re: Tubbing a 1200 ute |
Not too shy to talk
From brisbane
you cut out the rear wheel arches out and weld big ones in so then you can run bigger tyres
Posted on: 2008/3/27 2:19
From newcastle nsw
tubbing a 1200 ute is really no good unless you are going to run 17" cheese greater with the ute on its ass unless you move your rear chassis rails as the stock wheel arches only go in as far as the chassis rails so there is no real point unless you are going for looks i have a set of rear tubs that came out of my parts ute here im probably going to put them in my ute but there mainly for looks
Posted on: 2008/3/27 3:03
thats exactly what i thought.
it is mainly for looks plus a lot of traction, looks like its back to the drawing board
Posted on: 2008/3/27 3:39
From Gold Coast
check out my thread... chassis rails moved in, i'll be fitting a 10 inch tyre under the back:)
Posted on: 2008/3/27 7:30
My 1200 ute project
From Canberra
Posted on: 2008/3/27 8:19
From Brisbane
As has been said, you can cut out the original tubs and put larger tubs in but it is purely for looks unless you either move the springs in line with the chassie rails (probably best described as mini-tub) or go all out and move the rails and springs (like Josh).
Speak to an engineer though!! Put some pics up while as you go
Posted on: 2008/3/27 22:01
