Wider diff
From 6065
does anyone know of any diff with datsun stud pattern thats 7cm wider than a 1200 diff drum to drum?
Posted on: 2008/3/29 5:42
Re: Wider diff
From newcastle nsw
i could be wrong but i think the 120y difs are about 3 inches wider so thats ruffy what you want correct ???
Posted on: 2008/3/29 5:49
Re: Wider diff
From 6065
cheers ill check it out,i measured the 81 sunny diff but same width,so is the 76 corolla.
Posted on: 2008/3/29 5:53
Re: Wider diff
I just measured my 120Y diff at roughly 130cm. I have a 1200 ute diff in my 120Y and the width is pretty much the same.
Posted on: 2008/3/29 5:57
Re: Wider diff
<--- wikiQuote:
Drum-to-drum Width:
Datsun B10: 48.8 in (1240 mm) H145 diff
Datsun 320 50 in H190 diff
Datsun B110: 51.36 in (1305 mm) or 1185 mm axle flange-to-flange (less brakes)
Datsun V510: 53 in (http://forum.ratsun.net/showthread.php?t=2401)
Datsun 521 53 in
Posted on: 2008/3/29 6:19
Re: Wider diff
i have a falcon xp 4 x 114.3 diff in my backyard that is about 9cm wider than stock... if that helps with measurements.
1385mm drum to drum
Posted on: 2008/3/29 6:26
Re: Wider diff
From NZ
K-DOGG wrote:
cheers ill check it out,i measured the 81 sunny diff but same width...
That's surprising. The B310 is about 3" wider than a B110 so I'd have thought the diff would be at least a bit wider.
In any case, although I don't know the width, how about AE86 Corrolla (which I think also have discs) plenty of diff ratios, LSD options etc. Another thought is '70s/early '80s Mitsi Lancer or Gallant.
On my 1200 Coupe racecar I run a Ford Mk 2 Cortina diff (Sacrilege I know!). Plenty of ratios/ LSD options etc. Leaf spring mounts are same spacing but it's wider than Datsun. (Wider still is Escort diff.) Simply redrilled the stud pattern. Either way there's obviously some mods required so this was no biggie.
Posted on: 2008/3/29 7:12
Re: Wider diff
From Canberra
yeah I'd be looking at toyota ae86 it T18, or stanza? bluebird? 1600 wagon?
Posted on: 2008/3/29 7:16
Re: Wider diff
From NZ
Good thinking - 910 Bluebird must surely be wider? Assuming they ran these in the Bathurst Turbo racecar they should also be strong?
Posted on: 2008/3/29 7:27
Re: Wider diff
From Sydney , NSW
I have a C20 Vanette diff in my racecar - not sure how much wider but it would be about the 90mm mark I suspect
It will be up for sale soon as I will be going to a ute diff while we build a H190 floater
Cheers
Posted on: 2008/3/29 8:50
All torque, no traction
A division of "My mate's ....." engineering
