« 1 2 (3) 4 »
Re: 20grand FJ20 ute
From Canberra
I dont think it was ever engineered though?
I don't know either. But if it was then it would've been worth it!
Posted on: 2008/3/28 1:50
From BRISBANE, QLD
Lachie wrote:
Kirstie works with a couple of blokes who built some FJ20 utes back in the day
They wouldn't be PRO12T & TIG20T the green & tiga mica 1200's would they?
Wouldn't that mean that the cars were engineered in the ACT but regoed in NSW?
I tried everything to see if I could go 2.0L. But they wouldn't have any of it. They won't even let you bring in an already engineered car from another state and get it re-engineered in ACT.
TALK TO SCOTT AT MADDAT. I CALLED HIM LAST NIGHT AND ASKED ABOUT THE SR20DET IN 1200'S AND HE SAID THERE IS A WAY TO DO IT IN EVERY STATE.....DON'T REMEMBER HIS EXACT WORDS BUT HE GETS THEM TESTED BY ENGINEERS AND THERE IS A LOOP HOLE TO GET PASTED THE ADR COMPLIANCE ISSUE
APPARENTLY A TURBO V6 IS POSSIBLE...NOT SURE IT WOULD FIT THO
Posted on: 2008/3/28 2:02
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
Quite a regular
there was a bloke in narangba near me who had a 1200 sedan with a sr20 in it one of my mates was there when he got it registered he had it mod plated and everything but 2 months down the track main roads pulled him over and raped him for everything.
Posted on: 2008/3/28 2:23
From Canberra
Doesn't bother me My 1200 is at V&E geting a CA18 dropped in as we speak
Posted on: 2008/3/28 3:09
From BRISBANE, QLD
thats the way i have gone and will do again...wicked tough motor
Posted on: 2008/3/28 4:12
From Far, far away
to be classed as an ICV, im pretty sure your engine will have to comply with euro emission standards?
Yeah, the current ADR's will have provisions for emissions, so they do have to be met. A lot of engineers will tell you a motor wouldn't pass this, but I reckon they just don't want this kind of work.
Does anyone actually know the emissions standards. IMO if there was a huge difference they would be more stringent on engine swaps than they already are. If a CA was shonky compared to today's standards they'd frown upon engineering one in a 1200.
Posted on: 2008/3/28 4:46
From Darwin NT
yeh ive heard of that loop hole you have the car registered in buisness then say it needs more power due to heavy towing loads and so you can go larger apparently there was also someone who got a 13b turbo registered in a ute via that loop hole?? not to sure but thats what i was told
Posted on: 2008/3/28 4:47
current project 4x4 patrol...
From Tamworth , NSW
there is a massive difference between an engineswap and having a vehicle classed and registered as an ICV
from the qld icv rules
ICVs built with production vehicle body shells-
A monocoque body shell from a production passenger car (MA category)
will not be considered as the basis for an ICV unless:
Posted on: 2008/3/28 5:03
I have a 1200 ute with a fj turbo in it,but it was engineered in 2000 with front mount bw diff and everything else
Posted on: 2008/3/28 7:20
the 1200 ute MYDRUG has an sr20det engineered in it in nsw and that wasn't done that long ago. So there is ways around it, HOWEVER as previously mentioned in this thread, the RTA reserve the right to revoke any engineers certificate if they feel it's appropriate.
Alot of engineers do get investigated if they start passing dodgy ####, have had mates with issue before.
I've heard the way pac cars do their stuff is put a 13b in, grind of the 13b tags on the side of the housings and mold the 10a ones on, restamp an engine number and off you go.
Physically unless you've seen a 10a and 13b beside each other I doubt you'd know.
Posted on: 2008/3/29 12:30
« 1 2 (3) 4 »
