Its that time
From South Africa
Hey all,,,Need your guys advice again.
My A14 ute has come to time that it requires some mods
I need advice desperately, any opinions welcome.
Ok then, here goes,
I need more speed...LOL
-I will be puttin in extractors and perfromance exhaust made a co, called COWLEY.
-Will be puttin in an ignitor sytem to replace points system in dizzy.
WHAT CARBI SHOULD I USE?????
CAMS????
P.S. I dont wanna do major mods, just mods to my present, a14, b14 engine....
Oh,,, And i dont want the su type gx carbs etc, cos I dont want change manifold etc etc.
Guys in South Africa JHB, if u have stuff for me as well, pls reply
I need more power,,,
PLS HELP
Thanks all
Posted on: 2008/3/31 9:47
Life's a bitch, so f...k it.
Re: Its that time
From Darwin NT
little 32/36 dgav weber? all you need is an adapter plate to suit you manifold or maybe a single sidedraught weber (you will need to buy a manifold for this though) as for cam specs i know nothing about them
Posted on: 2008/3/31 11:26
current project 4x4 patrol...
Re: Its that time
From Perth WA
Cam is a 'major' job. Required the engine to be pulled out and stripped.
a 32/36 wont give you THAT much more power. But from my experiance, alot better running and crisper performance. Webers, efi, SUs or turbo are the go for power!
Headwork will get you some more power if you match it to a neat set of carbies (SU/weber).
Posted on: 2008/3/31 11:32
Chris...
