Datsun wheel PCD - 114.7mm or 114.3mm???
From Melbourne ( West )
Can anyone help???
I was going to buy set of wheels with a
PCD of 114.3 - The wheels are off an RX7 S3.
Does anyone know if they will fit a 1200 too???
I know this site says a PCD of 114.7 or 4.5 inches for Datto's, but
4.5 inches works out to be 114.3 almost spot on.
Anyone used RX7 Series 3 wheels before?
Thanks...
Sam.
Posted on: 2008/2/25 8:23
Re: Datsun wheel PCD - 114.7mm or 114.3mm???
From The garage, NZ
1200 PCD = 4x114.3
If wheels are 4x114.3 then they will fit the bolt holes. Weather the offset if right is another tale
Posted on: 2008/2/25 8:25
Nissan specification is 4.5 inches, they used the British spec -- perhaps because they built thousands of Austins...
In any case, that works out to 114.3 mm.
Posted on: 2008/2/28 5:34
From Beautiful Sunny (sic) Melbourne
Series 3 RX7 is FIVE x 114.3
Too many holes!
Posted on: 2008/2/28 7:41
Too many holes!
??? Just going by what I saw on Ebay... There was a picture of a set of 4 simmons (with 4 stud pattern) and the add stated that he was unsure of what else they would fit but they had just come off his Series 3 RX7.
Posted on: 2008/4/6 1:03
From Adelaide. SA
Series 3 RX7 is four stud, They didn't go to five stud until series 4.
Offset will be an issue though
Adam
Posted on: 2008/4/6 1:06
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Canberra
Series III RX7's are 4x114.3, Series II & Is are 4x110.
Posted on: 2008/4/6 1:07
From Sydney, Australia
All the early mazda stuff is 4x110 also like rx2 rx3. So Datsun people shouldn't lurk around on Mazda Forums, except to get rx7 550cc injectors.
Posted on: 2008/4/6 1:57
