L series into 120y
From Sydney
ok so im thinking of putting a L series into 120y,
probaly L18 or L20
i have searched and is it true that i should use 180b engine crossmember
any other info out there has anyone here done this ?
what about gearbox clearance in the 120y tunnel with the l series box ?
il probaly use R31 or 180B struts as ive already got them ...
Posted on: 2008/4/9 2:03
Re: L series into 120y
From Brisbane, Australia
i have searched and is it true that i should use 180b engine crossmember?
yes its true. you'll find a 2nd set of holes for the 180B xmember when you remove the standard one. you'll have to trim a little off the rear edge of the 120Y's castor rod brackets to allow it to fit though.
heaps of room.
http://datsun1200.com/modules/myalbum/photo.php?lid=613
heaps more info on the site if you search for it
Posted on: 2008/4/9 2:16
From Sydney
thanks for that i have been searching but not to hard ,
your pics and info i have found are a great help ,
thanks !!!
Posted on: 2008/4/9 2:26
