Electronic Ignition Wiring Question
Nissan engine A15 with the electronic dizzy with the black box attached. Going into a non nissan application. Hows the wiring go??
Going off what I see in thispic (presuming) that the ignition 12v hot (+) will go to the dizzy, then from the dizzy to the hot side of the coil.
Please some one correct me if I'm wrong.
On another note which Terminal is which on the distributor??
Posted on: 2008/4/15 3:08
Re: Electronic Ignition Wiring Question
From San Diego, CA
Looking at the diagram you are correct. Ignition switched power goes to the dizzy black wire with a white stripe then to the to the coil positive. The blue wire from the dizzy connects to the negitive side of the coil.
Posted on: 2008/4/15 4:36
so does the coil ground through the dizzy?? As the diagram also shows a ground on a direct hot line which would cook the wiring..
Posted on: 2008/4/15 5:13
From San Diego, CA
Yes the coil grounds threw the dizzy. The part in the diagram that you are seeing with the + going to ground is the condensor wired in. The condensor connects to the hot lead on one side and ground on the other.
Posted on: 2008/4/15 5:22
Exactly right:
1. The two wires on the distributor go to + and - terminals of the coil
2. remove the old coil, replace with 12V coil
3. bypass the ballast resistor.
4. Add a (required) condensor on the hot side
5. Add an (optional) tachometer to the negative side. NOTE: Factory tachos don't use this line
More pics and explanation here: club wiki - B310 Electronic Distributor Swap
McD, which state are you in?
Posted on: 2008/4/15 5:41
Thanks makes more sense now
I'm in Maine
What size condenser by the way??
Posted on: 2008/4/15 5:57
I don't know how condensors are measured. You could just go to wreckers and get one from a 1978-1983 type Datsun (any kind). Oh, probably not any in Maine though. Maybe one from any other car.
Well from the wiring diagram it appears you may not need one. They show one for the alternator, but not one for the distributor.
Posted on: 2008/4/15 6:27
About the only datsuns you find left up here are the old 280z and 300z.
Now how do you tell which terminal is which on the distributor??
Posted on: 2008/4/15 7:00
From San Diego, CA
They are measured in uf (micro farad). A condensor from the old 280z should work fine the values on most of them are pretty close if not the same. You could also buy one new from your local auto parts store. They are normally in stock for most vehicles.
Posted on: 2008/4/15 7:59
From Bendigo, Victoria, Australia.
if you put them on the wrong way you won't get any spark... so just try if there are no markings.
i've been running a JTS high energy coil with elec dizzy for some time now and at no stage have i run a condenser on the coil. i have one on the alternator i believe
Posted on: 2008/4/15 13:22
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
