Re: Indicator Troubles...
From sydney australia
It will most likely be the flasher canister, that's the little relay that causes the lights to go on & off. Any parts store should be able to sell you a new one for a reasonable price. A mates pulsar was doing exactly what you say your's is doing & a new canister fixed the problem. 1200's usually have a 2 pronged canister, as you get them in 2 & 3 pronged varieties. Have a look up under the dashboard & you should be able to see the old one.
Posted on: 2008/4/17 4:28
Subject Poster Date
     Indicator Troubles... 1200wags 2008/4/16 1:13
       Re: Indicator Troubles... boostboy 2008/4/16 1:21
         Re: Indicator Troubles... 1200wags 2008/4/16 7:57
           Re: Indicator Troubles... b310gx 2008/4/17 4:28
             Re: Indicator Troubles... 1200wags 2008/4/17 7:18
               Re: Indicator Troubles... _Shmity_ 2008/4/17 11:17
