Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
A Series Datsun Gearbox Speedo Drive
oliver-morrisminor
Posted on: 2008/4/19 7:54
Is it common for the speedo drive in the G/box to Brake?
My speedo was making some noises, the needle bounced a few times then went to "0" & has stayed there. Upon investigation there was a slight kink in the cable, so I bought a new one. and it works fine on the speedo powered by a electric drill, but it won't move when connected to G/Box. How do you fix this?
#2
Re: A Series Datsun Gearbox Speedo Drive
Pendles
Posted on: 2008/4/19 8:03
I've broken one previously.
It's only a (10mm)? bolt to pull the speedo drive from gearbag to check it out, and the gears only made of plastic. Probubly pick one up from the wreckers for nothing. You can view topic.
