Re: How to wirie up a Fuel Pump?
From Wallan, Vic, Aus
Ah okay, thanks, but I already bought a relay, t'was only 10 or 20 bucks. My brother is an sparky and is doing the work for me. We understand everything thats been said except what is the "Fuel Switch" that Ang put in the drawing?
Posted on: 2008/4/20 12:42
From Castro Valley,CA USA
Its a switch on the dash.
The pump will run if the switch is "ON"
AND
there is oil pressure OR the little overide button is pressed.
Do you need it? I don't know.
At this point I should probably declare that I still don't have an electric fuel pump. My car was in pieces a while back and I decided it was easier to add the wiring at that point for future use. I did however check to see if the wiring worked and it did and still does.
Posted on: 2008/4/20 13:30
From Burbank, CA
lol fuel pumps... i don't even have one.
Posted on: 2008/4/20 16:33
|||\ 81 KPB310 /|||
« 1 (2)
