Re: need more power!
From South Brisbane, QLD
I'm with Tommy, get your hands on a a14 or a15, there seem to be a few floating around at the moment as the newer engine conversions go in. should cost you somewhere around the $500 mark depending on the condition, then get a downdraft weber (cant remember the type), extractors, exhaust and the trx's and you should have a fair bit of change for some fluffy dice or whatever else floats ya boat.
Posted on: 2008/4/30 12:16
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
From Far, far away
hey mate, yeah TRX rims do fit. however i needed spacers on the front.
What struts are you running? Has anyone else needed spacers for TRX rims?
Mine fit fine.
Posted on: 2008/4/30 12:35
From Mildura, Victoria, AUS
77datoute wrote:
What do u mean spacers? and how much do trx rims usually cost
i got my trx rims for $300 with 2 brand new tires n 2 wrecked ones, i dont know if that helps or not..
Posted on: 2008/4/30 13:13
From sydney australia
If you're going to try & find an A14 or A15 from someone who took it out of a 1200 ute, see if they will sell you the engine crossmember as well, or swap them your original. This will get you a drop in fit & they can cheerfully cut up your one. Later 1200 utes came with the 120Y style block,so adaptor plates are needed to fit an A14/15 to your wagon, unless you can get the correct crossmember. Plans for the adaptors are here on the site, in case you can't find anything.
Posted on: 2008/5/1 2:29
From adelaide hills
Hey BigD can u go into some more detail about workin heads and so on. ( u r talkin bout an a12 right!!)
Posted on: 2008/5/2 11:11
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
« 1 (2)
