T3 Pre- FAb'd Manifolds for CA18DET*** ?????
Not too shy to talk
From SOCAL
Greetings,
I am looking to see if you guys down under have or know of any places that sell pre-fab'd manifolds for our lil 1200's.
I have a T04E that i will be running on my B110.
and i am not looking to run a Ebay one.
just checking my options before i commit to getting a custom one.
Posted on: 2008/5/2 8:48
Re: T3 Pre- FAb'd Manifolds for CA18DET*** ?????
From Adelaide
You can always weld a t3/4 adapter onto you cast manifold. I did this years ago on my s13 and it worked well, cheap to do. Make sure you shot peen the weld though, other wise it has the potential to crack.
Posted on: 2008/5/3 0:23
XR6T 320rwkw
Stock 1200 Sedan
1200 Sedan, S/C a15
Not too shy to talk
From SOCAL
We discussed that option too but with my 1200 its LHD, so the t25's hotside was already pressed againest the steering box and with the T04E it won't clear unless I stack washers on the motor mount to bring the motor up some....
Posted on: 2008/5/3 2:55
From campbelltown (sydney) australia
a top mount manifold will remedy this use a t28bb as well goes very well with three inch exhaust
Posted on: 2008/5/3 3:37
* caution, sunglasses must be worn to view my ca18det *
Not too shy to talk
From SOCAL
Ya a top mount would work, but the other thing I found is the turbo wil have to be angled facing the 5 o'clock position if overloking the motor because now the brake master cylinder will cause issues with the downpipe....
Posted on: 2008/5/3 4:24
From BRISBANE, QLD
is it internal or external wastegated?? i have a tubular manifold made as a low mount, it sits really close to the block so may work...but it hasn't got an outlet for an external wastegate
Posted on: 2008/5/3 4:43
Back after a long absence and looking to build a beast starting with a 1974 1200 sedan
Not too shy to talk
From SOCAL
Externally gated, I can have it modded for external....
Its easier for you guys since your box is on the other side...lol
Any pics of your manifold?
I'm in no rush since I have a BB T28 spec r turbo also... ;)
Posted on: 2008/5/3 5:40
