Question for CA/SR boys (turbo)
From Bendigo, Victoria, Australia.
Hey all. just a quick one. Does a T28 fit up directly in the place of a T25?
Only reason i ask is because i have made all my piping to suit a T25 which i now have discovered is beyond repair (seals, bearings, worn housings). T28s seem alot more common and i was just confirming that all my piping will fit up no worries if i go with a T28 over a T25? ie compressor outlet (and compressor inlet and turbine inlet and turbine outlet) flange patterns, actuator angle, and oil lines all the same?
i am pretty sure they are, i just don't want to take the plunge and then have to fab up more pipes!!!
Cheers
Cam
Posted on: 2008/5/6 10:20
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
Re: Question for CA/SR boys (turbo)
From campbelltown (sydney) australia
exhaust fits front duct might not turbo/i/c pipe might not the turbo looks the same but is overall slightly bigger
Posted on: 2008/5/6 12:04
* caution, sunglasses must be worn to view my ca18det *
From Brisvegas, oz
flange is the same thats about all i know
Posted on: 2008/5/6 12:23
www.camerasplus.com.au
From Adelaide
fits perfect, no modds to the exhaust,
need to bend the water line little bit, also use a braid line for the oil return,
intercooler piping with be different
Posted on: 2008/5/8 2:04
From Brisbane
T25G is a direct bolt on, T28 as crzy_ute said, my intercooler piping worked / fitted when i changed to the T28, just had to tcut off about 12mm from the piping, both turbo's will need the compressor housing rotated to miss the standard exhaust manifold
Posted on: 2008/5/8 4:49
