#1 questions
bigo Posted on: 2008/5/6 22:30
sort of new to the datsun scene, had a ute when i was a young squirt. got a couple of questions re 1973 vb110 wagon since i am having trouble getting spares.
i know front quarters from a ute fit my wagon. cause i've got some.
will the front doors from a ute fit my wagon.??
will the rear doors from a sedan fit my wagon.??
will the bottom sill from a ute fit my wagon.??
cheers for any help.
#2 Re: questions
cheater_5 Posted on: 2008/5/6 22:38
ahh another wagon owner.
Welcome.
Wagons are quite different in some respects.
I assum its a 5 door? Someone in aussie will have to answer the door questions as the doors are smaller on a 5 door.
As far as the sills go, they are pretty chop and change. Would be able to match it up no worries.
any pics of your woman pulling machine?
#3 Re: questions
bigo Posted on: 2008/5/6 22:51
#4 Re: questions
Dodgeman Posted on: 2008/5/7 1:07
Welcome to the forum. To answer your questions in order.
Yes, all 1200's use the same basic front guards with some minor variation in other countries. [USA uses big ugly side lights]
Ute doors should interchange on 4 door Wagon.
4 door Sedan rear doors should interchange on 4 door Wagon.
The ute sill can be used as a repair panel, but I don't think it's long enough for passenger models to use as a 'replacement'
#5 Re: questions
bigo Posted on: 2008/5/7 3:21
thanks for the answers guys. i will post some pics of my wagon when i figure out how to do it. in the mean time, i love reading all about your projects and learning a heap about what i can do with mine.
my project is slow going but i will post updates as they happen.
thanks again.
#6 Re: questions
b310gx Posted on: 2008/5/7 5:01
The rear doors from a sedan wont fit a wagon. the sedan roofline curves down & the door frame curves down to match, while the wagon roof line continues back in a straight line. The sedan & ute front doors will work, along with the front guards & the lower sill section. As it's only the frame work for the door glass you might be able to swap these over from the wagon doors to the sedan doors if you need to.
#7 Re: questions
A14force Posted on: 2008/5/7 7:51
two door sedan doors fit two door wagons....
#8 Re: questions
cheater_5 Posted on: 2008/5/7 8:40
pity we got none from nissan ae bart
#9 Re: questions
Dodgeman Posted on: 2008/5/7 11:09
Thanks for that as I obviously hadn't realised that. I remember new door shells being sold & advertised as being suited to sedan & wagon, so I drew a conclusion that I shouldn't have. [stores correct info in memory bank]
