Re: 1200 coupe race suspension setup?
From Brisbane, Australia
do you mean you have 4 flipped leaves?
how much droop travel do you have? measure it with and without the shocks attached.
what shocks? are they an off-the-shelf part for a 1200 coupe, or are they from another car?
my initial impression is that your rear leaf springs are all wrong. not that they're too hard, because that would make it oversteery, but that you don't have enough droop travel available and they're working against the shocks.
Another possibility is that the rear shocks are too stiff in rebound - if they are designed for another car?
understeer can be caused by alot of things. what is your front ride height (from centre of wheel to edge of gaurd?
what front spring rate?
what sway bar?
locked diff?
Posted on: 2008/5/7 3:57
Subject Poster Date
     1200 coupe race suspension setup? jared 2008/5/7 3:11
       Re: 1200 coupe race suspension setup? sikyne 2008/5/7 3:53
         Re: 1200 coupe race suspension setup? sikyne 2008/5/7 4:02
         Re: 1200 coupe race suspension setup? jared 2008/5/7 4:32
           Re: 1200 coupe race suspension setup? L18_B110 2008/5/7 4:50
             Re: 1200 coupe race suspension setup? bert 2008/5/7 6:35
               Re: 1200 coupe race suspension setup? bobthebuilder 2008/5/7 10:56
                 Re: 1200 coupe race suspension setup? sikyne 2008/5/7 23:25
                   Re: 1200 coupe race suspension setup? Rallytwit 2008/5/8 7:36
       Re: 1200 coupe race suspension setup? L18_B110 2008/5/7 3:57
       Re: 1200 coupe race suspension setup? Rallytwit 2008/5/7 4:40
