#1 clutch slave used for ca18det transplant???
waz1200 Posted on: 2008/5/5 12:13
just usin this master on my 1200 ute with ca18det but just wonderin if anyone knows if i use standard 180sx slave or 1 in pic please help
#2 Re: clutch slave used for ca18det transplant???
waz1200 Posted on: 2008/5/5 12:16
ok pics not workin for sum reason heres the link http://datsun1200.com/modules/myalbum/photo.php?lid=7499
#3 Re: clutch slave used for ca18det transplant???
Mildman Posted on: 2008/5/5 13:09
You have to go to the link - right click on the image - select "Properties", then select the text in the location field. (which is this http://datsun1200.com/modules/myalbum/photos/7499.jpg) and use that when you click the IMG button.
#4 Re: clutch slave used for ca18det transplant???
dattodude Posted on: 2008/5/5 21:12
I used an AE86 clutch master and the standard CA18det slave cylinder.
#5 Re: clutch slave used for ca18det transplant???
waz1200 Posted on: 2008/5/6 9:35
thanks for the tip!! on addin pics!
n so it should be fine to use standard clutch slave cylinder on ca18det box!
#6 Re: clutch slave used for ca18det transplant???
old_school Posted on: 2008/5/7 13:05
As long as the slave you want to use matches the master cylinder. Travel distance and capacity.
Will be fine. I use Mazda capella/RX4 slave cylinder because of its shape and a Ford Econovan Master Cylinder inside the car.
#7 Re: clutch slave used for ca18det transplant???
crzy_1200_ute Posted on: 2008/5/8 1:54
www.maddat.com.au
u pay for the product NOT THE NAME, ther gear is mad,
if u plan on doing it right do it from the starrt..
