WTB toyota 5 speed t2 or t3
From Darwin NT
like the title says im after a working toyota t2 or t3 gearbox pretty urgently in sydney or central nsw i dont really want to pay for shipping
pm me if you intrested in selling a gearbox
cheers
Posted on: 2008/5/8 0:29
current project 4x4 patrol...
Re: WTB toyota 5 speed t2 or t3
From Springwood NSW, Formerly Tas.
just a help, try Rollaclub and your after a T50 of a 2t or 3t,
the celica and t-18 boxes are differnt lenghts, not sure on the "AE71" corolla t50
but yeah have a look on there
or AE86 Driving Club
i've got one here, but yeah bit of a prick to post/ship
Posted on: 2008/5/8 2:46
1978 120y Coupe.
From Coondle, WA Australia
There were infact 3 different lengths of T50 box from different years, and none of them fit into the existing shifter hole perfectly.
And there are 21 and 23 spline versions too.
They all fit the tunnel without too much pain.
I actually had trouble getting one in Perth. All the wreckers didnt stock em since they were too old.
The rollaclub is a good place to start and get info about which cars they came from. I had a thread with heaps of details not long ago.
2t vs 3t stuff
and a search yields heaps of stuff
Posted on: 2008/5/8 11:31
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Darwin NT
yeh thanks guys whats the difference in the shifter holes? and how well do they fit in a 1000 tunnel? i know the mounts arent the same thats not an issue ill move my original mounts
Posted on: 2008/5/8 11:59
From Tamworth , NSW
i think its 40mm
Posted on: 2008/5/8 13:06
It depends on which of the three you get. The very early ones were the shortest, and in a 1k will be miles short, and perhaps unusable since the stick is almost under the dash.
The mid length ones, the stick will fit thru the original hole when in 4th gear. ie its at the very front of the hole, so you need to cut the other half of the hole to make it work.
The last version and the longest is the opposite of the mid sized version. when in 3rd the stick will fit thru the original hole, so you need to cut the other half of the hole further back.
The boxes themselves are indentical, all toytoa did was put extension linkages on the shifter to move the stick further back in different models.
As far as fitting into the 1k tunnel, its like a dream. You will need to completly remove the original mounts and make either new mounts or sandwich plates up to suit.
I am currently in the process of attempting to bribe a fellow datsun owner with a a15/t50 box setup in a 1k coupe to let me borrow the mounts so that I can get them copied and fabricated. When I do, i plan to post the cad templates up so that everyone can use them.
Posted on: 2008/5/8 13:25
