Swaping Diffs
From Sydney
Hey guys,
I am going to swap the diff out of a datsun 120y into my 1200 ute this weekend and wanted to know will this be a straight swap or will i have to do some modification.
Is there anything i need to watch out for?
Posted on: 2008/5/9 0:08
Re: Swaping Diffs
If you have an early ute with the H145 diff, then the H150 diff from a 120Y will fit but a 2mm spacer & a second gasket is recomended.
If you have the later H165 rear end, then the H150 diff will not fit.
Posted on: 2008/5/9 0:14
Love your Datsun.
Treat it well.
Re: Swaping Diffs
From Sydney
hmm and where can i find the diff i have i assume i will be stamped on it somewhere ?
Posted on: 2008/5/9 0:16
Re: Swaping Diffs
The early H145 is a little diff while the H165 is quite a bit bigger.
If your diff is physically larger that the H150 [120Y] diff, then you have a H165, but if it is a little smaller, then you have the H145.
Do you know exactly what model your ute is?
Posted on: 2008/5/9 0:28
Love your Datsun.
Treat it well.
Re: Swaping Diffs
From Geelong, Vic
are you wanting to swap the whole assembly or just the centre?
Posted on: 2008/5/9 6:41
Re: Swaping Diffs
From Sydney
i was just wanting to swap the center and my ute is a 79 model too :)
sorry for the late reply the site wasnt working for me earlier!!!
Posted on: 2008/5/9 14:08
Re: Swaping Diffs
No can do. 120Y came with either H145 or BW68 diff. 1979 1200 Ute came stock with H165 diff.
Posted on: 2008/5/10 3:21
Re: Swaping Diffs
From sydney australia
Why do you need to swap the diff?Is it broken or do you just want a different diff ratio. You can get different ratio's for a H165 from a variety of other models, 180b Wagons, Series 1 & 2 Bluebirds, Early Stanzas & some Vanettes. There is info in the technical directories, or some body else might help.
Posted on: 2008/5/10 6:37
Re: Swaping Diffs
Aussie 120Y's came with the H145 during 1974, then H150 for all imported 120Y's after that.
Australian assembled 4 door Sedans from July 1976 came with the Warner rear axle assembly.
Posted on: 2008/5/10 7:26
Love your Datsun.
Treat it well.
