« 1 (2) 3 »
#11 Re: what can i do about putting upto 300hp through a A series gearbox
Ronny_CTS Posted on: 2008/5/9 12:16
Could you take some pics of your engine...specially to the bellhousing and how did you bolt your engine to the crossmember...show some light on your conversion! its very interesting...
#12 Re: what can i do about putting upto 300hp through a A series gearbox
Dodgeman Posted on: 2008/5/9 12:24
To provide a possible solution to the question that you asked, I would suggest that to be able to use a 300hp engine in front of a 60 series gearbox would require a relatively simple change to your car.
Refit the original wheels to the rear, with stock cross ply tyres, & inflate them to the maximum permitted pressure. I suspect that you will have no gearbox problems after that & since gearbox life was the sole focus of the question, this will help, but tyre wear may be increased.
Very old tyres are recomended.
#13 Re: what can i do about putting upto 300hp through a A series gearbox
D Posted on: 2008/5/9 15:05
put the whole thing with a fwd box in the rear problem solved or hybrid two bellhousings and run a toyota box or mitsu sigma box.
#14 Re: what can i do about putting upto 300hp through a A series gearbox
dazza1200 Posted on: 2008/5/10 4:08
how much torque is the question
mazda rotary box, the larger toyota boxes or nissan silvia/skyline box would be typical
toploader T5 T10 tremec ,heavy but strong
whatever you do your going to be making a bell housing
dazza
if anyone knows of a CA rwd bolt on bell housing pm me
#15 Re: what can i do about putting upto 300hp through a A series gearbox
revhead001 Posted on: 2008/5/10 4:54
The holinger SD6. Because you know it's worth it.
OH YEAH. Give your car a birthday present today.
#16 Re: what can i do about putting upto 300hp through a A series gearbox
D Posted on: 2008/5/10 9:18
Sigma astron version have the borg x warner 5 speed, can handle a fair bit of grunt and separate bellhousing to boot.
The jap version gearbox has no sep bellhousing unfortunatelly.
#17 Re: what can i do about putting upto 300hp through a A series gearbox
Posted on: 2008/5/10 11:18
oh don, i can see whats coming for the 120y..... a 2nd hand slightly abused ex v8 gearbox for the a series.
#18 Re: what can i do about putting upto 300hp through a A series gearbox
revhead001 Posted on: 2008/5/10 11:21
Funny you should mention that. I have my eye on some of the unuseable parts.
#19 Re: what can i do about putting upto 300hp through a A series gearbox
Posted on: 2008/5/10 11:27
unuasebale for 400kw + but 100hp a series = perfect
#20 Re: what can i do about putting upto 300hp through a A series gearbox
BAD310 Posted on: 2008/5/10 17:45
Maybe someone knows what box the guy from Yatala Headworx is running behind his 260+hp A12
« 1 (2) 3 »
