#1 CA18det Starter motor - same as CA18de one?
blob Posted on: 2008/5/15 11:10
Does anyone know if the CA18det starter motor is the same as the CA18de one???
Also...
Difference between cam covers -
Ca18det - has raised section at breather outlets
Ca18de - has flat cam covers all the way (no raised section)
Is this correct???
Any help would be great...
#2 Re: CA18det Starter motor - same as CA18de one?
Burke_a_lot Posted on: 2008/5/15 11:23
sould be the same?
#3 Re: CA18det Starter motor - same as CA18de one?
blob Posted on: 2008/5/15 20:31
I thought so too...
If there was a difference at all, I would have thought the n/a would have been a 'higher tourque' starter due to n/a's having more compression??
...Cam cover info anyone???
#4 Re: CA18det Starter motor - same as CA18de one?
dattodude Posted on: 2008/5/15 21:41
For Starter motors: CA16/CA18 FWD is not the same as ca18 rwd. But CA18de rwd and ca18det rwd are the same AFAIK.
The FWD and RWD are a different shape and won't clear plenum reinforcements.
The cam covers are correct as you describe.
#5 Re: CA18det Starter motor - same as CA18de one?
blob Posted on: 2008/5/16 8:33
Thankyou!!!
That's a huge help...
