Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
torque specs
york
Posted on: 2008/5/17 1:14
hey people ,, i really need some help getting torque specs for my a15 engine,, need to know how tigh does the big end and small end need to be ,, any help really appreciated,,
#2
Re: torque specs
dat141
Posted on: 2008/5/17 8:20
TORQUE WRENCH SETTINGS
Cylinder head bolts 74 Nm - 54.6 ft/lb Connecting rod nuts (big ends) 37 Nm - 27.2 ft/lb Flywheel bolts 88 Nm - 65 ft/lb Main bearing cap bolts 59 Nm - 43.5 ft/lb Camshaft sprocket 47 Nm - 34.7 ft/lb Camshaft locating plate 8 Nm - 6 ft/lb Sump bolts 6 Nm - 4.4 ft/lb Oil strainer bolts 14 Nm - 10.3 ft/lb Crankshaft pulley bolt 196 Nm - 144.6 ft/lb Timing chain cover bolts 7 Nm - 5.2 ft/lb Rocker pedestal bolts 25 Nm - 18.4 ft/lb Valve rocker adjusting nut 22 Nm - 16.2 ft/lb Sumpplug 29 Nm - 21.4 ft/lb I'm not sure where these originally came from but I think they're right. I doubt you'll have any luck finding small end torque settings. You can view topic.
