a12 converted to l20b in a 120y 4dr sedan
here's a question, and it might already be on another thread, i have a chance to buy a 84 or 85 bluebird trx , i have a 78 120y 4 door sedan manual, i want to use it as a daily driver mostly, is the l20b an easy conversion or will it need alterations to the firewall and tunnel, do i really need to transfer the skyline struts it has or is that not absolutely necessary? is the borg warner diff strong enough to handle this conversion or do i really need to alter the rear diff and axle?, i just want the bigger motor... can it be done? and if it has been done by someone, how much did it cost, the car is a few hundred bucks with all good parts, .........
Posted on: 2008/5/17 8:58
Re: a12 converted to l20b in a 120y 4dr sedan
Ezy peezy lemon squeezy!
Posted on: 2008/5/17 9:02
heh heh...could you expand on that...please..
Posted on: 2008/5/17 9:03
if anyone has any info please please help me, this car is going to be so nice, i just need tips from honest people.. not shifty mechanics who seem to tell me how much money it will cost before telling me what they are actually going to do, i need info on cross member, transmission, clutch,diff..etc... all the details, thanks to anyone who responds...cheers
Posted on: 2008/5/17 9:15
For starters is the 120Y manual or auto? There are a few ways of going about it. If you hunt through the tech section you will find the info that you need. Some have done it by fitting a 180B front crossmember and some have used a modified stanza crossmember.
Personally I did not like either of the conversions as it would introduce bump steer. I used the mounting sections of a stanza crossmember onto my origional 120Y crossmember. Mine is a very neat fit. Have a look through my photo's and see for yourself.
What area are you from? There may be someone in your area that has done it all ready and may be able to assist you further. There is alot more to it than just bolting the engine in. But it can be done very cheaply.
Posted on: 2008/5/17 9:32
