Re: Head Machining/Shaving/Planing
From Townsville, Qld
Well if you were to machine the engine block the pistons would protrude which in turn will make it a bitch to setup so as to not hit the valves. Same problem happens when you take too much off the head too
Posted on: 2008/6/2 12:25
Subject Poster Date
     Head Machining/Shaving/Planing clyons8 2008/6/2 12:19
       Re: Head Machining/Shaving/Planing LittleFireyOne 2008/6/2 12:25
         Re: Head Machining/Shaving/Planing frankthedolphintrainer 2008/6/2 12:28
           Re: Head Machining/Shaving/Planing clyons8 2008/6/2 12:33
             Re: Head Machining/Shaving/Planing frankthedolphintrainer 2008/6/2 12:39
               Re: Head Machining/Shaving/Planing Curtis 2008/6/2 12:47
                 Re: Head Machining/Shaving/Planing clyons8 2008/6/2 13:03
                   Re: Head Machining/Shaving/Planing dazza1200 2008/6/3 12:27
