« 1 (2) 3 »
Re: posibly a dump question but ill ask it anyway.
From Brisvegas, oz
im pretty sure a stuffed head gasket will cause excesive blow by aswell.............edit just thought about it and it wouldnt back to the idea of your rings might be shot, maybe do a compression test.
Posted on: 2008/6/2 12:49
www.camerasplus.com.au
From Geelong, Vic
a spring on the dipstick isnt dodgy, its rally spec .....not that my engine has any blow by problems
Posted on: 2008/6/2 13:02
From Brisbane Australia
lets see ya run it down a drag strip without a spring ,for that very reason
Posted on: 2008/6/2 14:54
From Geelong, Vic
me run down a drag strip to prove i dont have blow by????
if so, that will happen soon enough
Posted on: 2008/6/2 15:04
From Adelaide, SA
i do have a catch can so maybe ill check those hoses, and like you said just keep an eye on it. i do get a bit of black smoke out of exhaust but no white.
Posted on: 2008/6/2 22:01
From sydney
hi guys i had the same problem on my car so what i done i put a vacum pump on it sucks all the pressure out of engine so it doesnt cause oil leaks (but mine car is a v8) shouldnt matter thou
Posted on: 2008/6/3 2:23
From sydney
I had the same problem on my Liberty RS she had done a few kays, it went away when I wound the boost down.
Posted on: 2008/6/3 5:40
From Adelaide, SA
what do you mean by a vacum pump. and how would i do this?
Posted on: 2008/6/3 12:46
Not sure how a vacuum pump works. In the meantime if your running big boost you might want to take it down a bit.
This may either minimise or stop the problem, the fact that there is still 'blow by' indicates that the rings are'nt as they should be.
Unless it is the blocked breather issue?
Posted on: 2008/6/3 13:23
From Adelaide, Australia
Dude, your breathers don't seem to vent anywhere they go into the catch can or do they vent back to the inlet manifold? For every inlet into your catch can, you need the equivelent venting. For example a hose from valve cover and one from block you would need two vents in the same size or one large one to vent the engine properly.
Posted on: 2008/6/3 13:53
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
« 1 (2) 3 »
