1200 with A15
Not too shy to talk
From Melbourne, AUS
i'm thinking of putting an A15 into my 1200, but before i did, i was wondering if there were any structural mods that need to be done to the car first? Do i need a different cross member or anything? or should the A15 just bolt straight in?
Posted on: 2003/6/6 9:13
Re: 1200 with A15
From Melbourne, Australia
couple of these will do the job, make em up, put em on your engine mounts then drop the a-15 in
mounting blocks
Posted on: 2003/6/6 10:20
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 1200 with A15
Not too shy to talk
From Melbourne, AUS
do those block weld straight onto the stock 1200 crossmember?
Posted on: 2003/6/6 15:03
Re: 1200 with A15
dont need to weld, you can just bolt em onto the stud that is already there (ontop of rubber mount)
unless you want to of course
Posted on: 2003/6/6 15:39
1200 Coupe Rallycar
Re: 1200 with A15
Not too shy to talk
i was thinking about doing the same mod will this also be needed for a 1200 ute?
also im trying to find a A15 motor but i dont know which car they came out of?
please help.....
Posted on: 2003/6/7 18:17
Re: 1200 with A15
From Warwick, QLD
Hey noisy13B yeah you will need to get those mounting brackets made up. I know the A15 came outta the vanette's I dunno what else but
Cheers
Damo
Posted on: 2003/6/8 4:09
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: 1200 with A15
demo is right but it depends on the year of the ute, if its 80+ you actually do not need this and it will slot straight in, pre 80 requires the plates
Posted on: 2003/6/8 12:16
1200 Coupe Rallycar
