Re: Head Machining/Shaving/Planing
From perth
if we are talking about angle milling we straighten up the valve angle ie:cut more off the spark plug side.you only do this stuff if you have done everything else first ,big valve port job etc and your looking for that last little bit
just get it faced flat again
none of us can tell you how much to cut off it .i would suggest minimum
we dont know how much comp you have or how much you need. turbo low comp methanol high comp
negative deck heights dont give piston to valve probs unless youve mashed a lot off the head too or have a big cam. can help to get the piston as close to the head as possible to reduce
detonation 0.030" clearance min.
you must measure all this stuff if your doing a modified motor .everything you change from stock may affect other things
dazza
Posted on: 2008/6/3 12:27
Subject Poster Date
     Head Machining/Shaving/Planing clyons8 2008/6/2 12:19
       Re: Head Machining/Shaving/Planing LittleFireyOne 2008/6/2 12:25
         Re: Head Machining/Shaving/Planing frankthedolphintrainer 2008/6/2 12:28
           Re: Head Machining/Shaving/Planing clyons8 2008/6/2 12:33
             Re: Head Machining/Shaving/Planing frankthedolphintrainer 2008/6/2 12:39
               Re: Head Machining/Shaving/Planing Curtis 2008/6/2 12:47
                 Re: Head Machining/Shaving/Planing clyons8 2008/6/2 13:03
                   Re: Head Machining/Shaving/Planing dazza1200 2008/6/3 12:27
