b310 front suspentions.
From malta
hey guys
i was wondering for a full adjustable front suspentions. does a 510/240 tention rod and lower arm go on a b310. i'm sure of the lower arm but the tention rod i'm not 100%
10x guys for all the help you give.
Posted on: 2008/6/5 19:45
Re: b310 front suspentions.
No, they do not.
The B310 has the same front suspension as the A10. In Japan and USA it is exactly the same, in Australia I hear they are different. But should bolt in if you use the set.
Posted on: 2008/6/6 6:11
From malta
but 510 and b310 or 210 have the same boltsetup into the ball joint. only that the b310's ball joint goes out a little like the one int the pic. am i right???
and if the lower arm is setable i thing it will perfectly go since u can adjust the lenght u want.
the only problem i see is the tension rod. im not sure about its lenght.
Posted on: 2008/6/6 8:22
From Adelaide, Australia
He is half correct, A10 is the later model 510 or in Australia called a stanza, this shares the same control arms/steering arms/castor rods as the b310. p510 is different.
Posted on: 2008/6/6 8:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From malta
but does a10 and 510 use the same arm and tention rod. can i share???
Posted on: 2008/6/6 8:43
You mean a 510 as in 68-73?? If so no it doesnt the p510 is only interchangeable with the p610 (180b) as far as I know.
Posted on: 2008/6/6 8:49
IPRA Build
From malta
the following is a pic of the lower arm of a 510 known by you as a p510 don't know the signification of the p. sry.
if it has the same balljoint bolt setup as b310. it it the lenght that is not the same??? a pic of the balljoints is in the reply i ve posted before
Posted on: 2008/6/6 8:58
