« 1 (2)
#11 Re: cut tail shaft
hotrocket Posted on: 2008/6/12 23:44
Try not to cut the tube in the middle, because you don't want a weld in the middle of the tailshaft. It creates a weak spot to shear around the edge of the weld.
yeah i thourght of that, the prob is the R31 t/shaft is a 2 peice, so im think il just give to the diff mob for them to do
#12 Re: cut tail shaft
bert Posted on: 2008/6/12 23:47
Excellent plan!!
#13 Re: cut tail shaft
DattoFrog Posted on: 2008/6/18 15:28
I used to work for a mob called Driveline Services. I don't know how far from Newcastle you are. They have a branch there. They are the people to talk to. We used to make and modify all types of shafts, street, strip and track work are their specilaity. Did a few in alloy(Group"A" gear). Worth a call.
#14 Re: cut tail shaft
hotrocket Posted on: 2008/6/18 21:27
DattoFrog wrote:
I used to work for a mob called Driveline Services. I don't know how far from Newcastle you are. They have a branch there. Worth a call.
Dubbo (160km) is alot closer for me than newcastle (560), All good thanks anyways
« 1 (2)
